MECOA's Model Engine Forum & Swap Shop Forum Index MECOA's Model Engine Forum & Swap Shop
Ask your technical questions on MECOA-K&B products at the bottom of the main page for factory tech help
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Info about Fuji .099SR BB ABC
Post new topic   Reply to topic    MECOA's Model Engine Forum & Swap Shop Forum Index -> Radio Control Glow Engines for Airplanes
View previous topic :: View next topic
Author Message
jocondor
PostPosted: Thu Feb 04, 2010 10:02 am    Post subject: Info about Fuji .099SR BB ABC Reply with quote
Hi to everyone, i need the help of real experts, i just bought on the bay this motor NIB, i know that BB means Ball Bearings but what about ABC?
I have more than one .099SR but no BB ones, and even if they are airplane engines i use them on my vintage buggies, they are very popular on small nitro buggies in the 80s.
Any info or tech sheet would be appreciated.
Thanks a lot for your help
jc
Back to top
View user's profile Send private message
ron bennett
PostPosted: Thu Feb 04, 2010 2:15 pm    Post subject: Reply with quote
ABC is an Aluminum piston running is a Bronze (or in the case of high performance engines, Beryllium), Chrome-plated liner. AAC is an Aluminum piston rinning in a Aluminum Chromed-plated liner. The idea is to more closely match the expansions at running temperature. The aluminum liner saves about an ounce in weight.
Ron Bennett
Monouth, OR
Back to top
View user's profile Send private message Send e-mail
PostPosted: Fri Feb 05, 2010 12:44 pm    Post subject: Reply with quote
Not quite correct. ABC is an aluminum piston running in a chromed BRASS cylinder. Not bronze or beryllium.
Back to top
dennis
PostPosted: Fri Feb 05, 2010 9:25 pm    Post subject: Reply with quote
I agree, and I'd never want to be near a machine doing work on Beryllium, talk about poisonous fumes. we have areas where it was mined where nothing will ever grow again.
dennis
Back to top
PostPosted: Fri Feb 05, 2010 11:35 pm    Post subject: Reply with quote
Yup, that's why Dumas quit making boat propellers out of the stuff.
Back to top
ron bennett
PostPosted: Sat Feb 06, 2010 11:45 am    Post subject: Reply with quote
If you contact engine makers, you will hear that brass alloys are way to soft for liners and most all makers used a bronze alloy, not brass. And, like I posted, high performance engines like Cyclon and Profi et.al., use beryllium liners on their better engines.
Back to top
PostPosted: Sat Feb 06, 2010 1:37 pm    Post subject: Reply with quote
You better check your manufacturers again. None use bronze and beryllium is a no no now as it is a known carcinogen. Has been for years. Dumas quit using in in boat props 25 years ago.
No one has ever used beryllium in engine cylinders. I think if it was used guys like Clarence Lee, Dave Gierke, and the other engine guys might have mentioned it. They would have also mentioned it if bronze was used. Brass is the metal of choice becuase of its coefficient of expansion.
Brone and brass are two completely different alloys. Bronze is copper and tin, Brass is copper and zinc.
I have two Profi engines and neither one uses beryllium.
Back to top
jocondor
PostPosted: Mon Feb 08, 2010 7:23 am    Post subject: Reply with quote
Thanks a lot for your replies!
Can someone suggest me the best mix % methanol, % oil (what kind, Castor, Syntetic...) , and % nitro methane, to run this small engines? Consider that i don't use them to fly, but on vintage rc cars that were made for them.
Back to top
PostPosted: Mon Feb 08, 2010 1:00 pm    Post subject: Reply with quote
Small engines like higher nitro as they give their heat of faster. I would use at least 15% nitro. That said, the engine you are using never was meant to be used as a car engine so I would not get weird with the nitro content. I would use at least 20% oil and I use 100% castor in all my engines. 2 or 4 cycle.
Back to top
PostPosted: Mon Feb 08, 2010 7:46 pm    Post subject: Reply with quote
Good advice Chief, easy on the nitro and use good ole 20% castor.
_________________
MAAC 32001
IMAC 3698
MECA 4762
SAM 5032
We have enough youth, how about a fountain of smart?
Back to top
Display posts from previous:
Post new topic   Reply to topic    MECOA's Model Engine Forum & Swap Shop Forum Index -> Radio Control Glow Engines for Airplanes All times are GMT - 6 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2002 phpBB Group
