Cox head question
Cox head question
Postby Frank Klenk » Fri Dec 10, 2010 6:44 pm
Do the 074 and the Med 09 use the same head?
Postby altidsulten » Sat Dec 11, 2010 1:34 pm
Hi Frank.
The Med. uses a glowhead like most of the other Cox engines, but the Queen Bee uses a glowplug that screws in the head.
Hope this makes sense?
The .074 glowplug looks like a normal glowplug. I can send you pictures if you are interrested? Putting them here is beyound my skills :?
Regards from cold Denmark
Thomas Pedersen
Postby chiefss » Sat Dec 11, 2010 9:06 pm
The plug for the Queen Bee IS a regular 1/4-32 plug. Short reach I think.
Postby dennis » Sun Dec 12, 2010 2:18 pm
The Medallion or TD09 head will indeed replace the Queen bee head and will give a small boost in performance to the engine. It will not be enough to overcome the Queen Bees title as the worst engine that Cox ever made.
Postby ron bennett » Mon Dec 13, 2010 12:18 pm
My vote for the worst Cox ever made goes to the cast case 0.049. VERY easy to strip and/or cross thread and wore out crank-to-case fit.
Ron Bennett
ron bennett
Return to 1/2A and alike
