It just wont start
It just wont start
Postby SharkBite1989 » Wed Oct 22, 2008 7:27 am
I have a .91 k&b inboard. I got it three weeks ago and it ran once now in just don't want start. i've put a new glow plug in it tried changing the starter leads and nothing. i'd like to get it out one more time before i have to put it away for the winter can anyone help me ??
Thanks but ive done the checking and still nothing its just being a pest
SharkBite1989
Boat motor
Postby max hansen » Wed Oct 22, 2008 1:51 pm
Take your glow plug out & check it to see if it will glow ,new ones are sometimes bad. Take your fuel line off tank ,put some tubing on filler , plug the vent & blow in the tube on the filler & see if fuel comes out . Put a piece of tubing on needle valve ,blow in it & listen in venturi for hissing noise .If you don't hear any open needle valve until you hear it . Carb may have junk in it & need cleaning . If you have fuel , compression & glow it should run .Good luck , MAX H. :D
