by johnnyblade » Wed Nov 01, 2006 11:59 am
i have a 7.5 inboard and it is the old style with rear exhaust.not sure what model but it has a gig carb on it with the push in velocity stack.I bought this motor on ebay and it was sopposed to be and unrun motor.i took out the piston and sleeve to inspect it before running and the sleeve looks unrun but has a spot about .375 dia.that has no chrome you can see the brass.is this normal? it is about .400 from the top of the sleeve and isright in the center of the intake ports(2 split ports) could really use some help,thanks :?
johnnyblade
Users browsing this forum: Bing [Bot] and 23 guests
