Updating two engines
Q&A on the KAVAN FK-50 twin now owned by MECOA
Postby happymcc » Thu Nov 20, 2008 8:34 am
In general are all parts available now for the Kavan ?
And specifically I am looking for two head gasket's as I have purchased an engine
partly restored with new jugs and pistons and want to fit the jugs to the old heads .
I also have one NIB Kavan Mk1 with the plastic gear and would like to change that
to the metal one , are they in stock ?
On more question . the engine I just purchased has the distributor ( sensor plate )
on the back cover . Can I use a C+H ignition I have with one of the sensors in that
cover ?
Thank you for any help
Keith
happymcc
Postby MECOA » Tue Feb 24, 2009 8:15 pm
No head gaskets right now, the project is on hold right now.
We do have metal gears amd bearings but there are other things that need to be altered.
Yes they are std sensors and should work.
Return to Kavan FK-50 Engines
Users browsing this forum: No registered users and 14 guests
