Veco 19 GP BB RC
Veco 19 GP BB RC
Postby XMoney » Tue May 04, 2010 1:25 pm
Hello, Am new to the forum. I am needing a little help on a Veco 19 GP BB RC . I think this was an engine that was in a car or boat. It came with a big drive pulley, and carb installed with the throttle lever that closes on the exhaust port. My question is : Can this engine be used in aero ? It has a mount that is over the nose of the engine and it has a bearing in it and, it has a set of mtg. holes in it. Can anyone help me out. I can take a few pictures of it if needed. Thanks, Jeff
XMoney
Postby MECOA » Wed May 12, 2010 8:32 pm
Need some pictures
Postby XMoney » Thu May 13, 2010 12:12 pm
I will post them tonite! Thanks alot.
XMoney
Postby XMoney » Fri May 14, 2010 9:29 pm
I will have to e-mail them to you. There does not seem to be a way to upload the pix. Can Isend them somewhere so you can view them? Thanks, Jeff
XMoney
Postby XMoney » Sun May 16, 2010 9:35 pm
OK ,Try This address to see the pics.
http://s807.photobucket.com/album
Thanks, Jeff
XMoney
Postby XMoney » Sun May 16, 2010 9:45 pm
That is just going to get to the photobucket homepage. Try a search for forkliftman albums . The album of photo's is named ; veco 19 .
XMoney
Postby MECOA » Tue May 18, 2010 7:53 pm
This is an early plain bearing Veco 19. It is an airplane enigne. It looks like you have a prop driver in the picture. All you need is a prop nut and washer.
Postby XMoney » Tue May 18, 2010 8:31 pm
I really appreciate the info on the engine. Are you talking about the little 2 piece bearing assy in the photos? If that is the driver , where can I get the washer and nut ? Can I order thru you? What do think about using the engine? It does have good compression. The NVA looks like new. Are there parts available? I did not see any listing on the site . Since some one ground the webs on the crankcase to fit that nose support for the extra mtg. holes, will that weaken the crankcase? I am going to start this engine soon and would like to mount on a plane I am currently working on. Thanks, Jeff
XMoney
Users browsing this forum: Google [Bot] and 77 guests
