Thanks for the post Saltmine, it got me motivated to get back to work on this project. I can't believe it has been 9 months since I worked on it.
Made good progress the past couple of days. Just about finished all of the
reed housings, ground the bottom lugs off all of the cases, and sized screws to attach cases to back plate. Here are more photos:
Cutting the Sure Start back plates down on the band saw left an uneven ridge on the reed housings which had to be smoothed off for a
good fit to the back plate. Used a late model case as a fixture for turning them with the drill press against a piece of aluminum covered with 280 grit sand paper.
Snugged up screws in the case:
Cut the heads off:
Ground them down on the bench sander so they would not protrude past the reed housing:
Here it is chucked up in the drill press:
The ridge really came off nicely. I would turn the housing a bit on the press
then take it out and check it. Took several passes but working slowly paid
off with a nice smooth even surface.
I ground the lugs off of the cases freehand against the disk on my bench
sander. It worked very well and holding them sure let me know when they
needed cooling down.
The reed housings needed to be ground to match the cases. They were
shaped freehand same as the cases.
Here are the cases and reed housings mounted to the back plate.
It is starting to look like a 9 cylinder radial now! Outside diameter is 5 1/8".
Weight so far is 14.1 ounces.
Its time to finish up the changes to the choke tubes! Thats next.
All that is left to do the the reed housings is final sizing of the inlet tube.
The grove in the one on the left is where the hole was for the Sure Start
spray bar. I'll take it down until the grove is gone. The one or the right is
almost there. An O-ring will seal the joint with the modified choke tube.
Should have more to post in a few days.
