Degum diesel engine
Degum diesel engine
Postby BRIAN PEART » Sun Feb 24, 2013 7:27 pm
Hi All
I am after the best way to degum a diesel engine that has be laying around for years any help would be great
Regards
Brian
BRIAN PEART
Postby eatherbreather » Mon Feb 25, 2013 4:36 pm
I ususally let them sit in acetone or some engine degreaser overnight - being carful to remove any parts (plastic) that may be adversely afected first. I then use an electric heat gun and WD40 to free the internals before disassembly. Make sure the piston is free to move up and down before unscrewing the fins/cylinder (if the engine is made this way) otherwise a twisted/broken con-rod will result.
eatherbreather
Postby collie » Sat Mar 23, 2013 2:44 am
soak it in tin of Radiator coolant for a few days[glycol]
collie
